Hi Guys
dnewnova
Hi Guys
Postby dnewnova » Fri Aug 03, 2007 2:12 pm
A drag racing newbee here with a question
My car is a 3rd gen Nova
and I am trying to figure out the spring rate I need for the front end
car weight is 3100# with driver and a 51/49% split to the front
I have a koni coil spring conversion on the front with rack and pinion steering, at present I have 12" 350# springs in there and its rock solid so how do I get a spring rate that will support the front end yet give me some energy to raise when I leave the start line.
hope that s not too dumb a question to start off with
Thanks
Postby draglist » Fri Aug 03, 2007 9:34 pm
I will leave the tech up to the other guys, but welcome to the board. bp
dnewnova
Thanks
Postby dnewnova » Fri Aug 03, 2007 9:46 pm
Thanks Bill
I hope to be a regular user and hope I can gain some knowledge i have always been into drag racing and raced a bike back in UK some 20years ago but this is my first attempt at building a car for Drag Racing.
I love drag racing, guns, rock and roll, my new 5"Dynomax Bullets.blower whine and the quiet life.
sorry you have to speak up
http://users.glowfoto.com/dnewnova
Postby jim sanders » Fri Aug 03, 2007 10:01 pm
8) WELCOME
Maritime Drag Racing
Postby Maritime Drag Racing » Sat Aug 04, 2007 7:59 am
350 lb springs are way too stiff. But how to figure out the right ones? Saw this method used many many years ago by a guy with a small block 1972 Camaro - he removed the springs from the coilovers, put a bottle jack on a scale under the centerline of the spindles and crawled under with a tape measure. He got me to raise and lower the jack a little bit a half dozen times then emerged with a number of 220 lbs/inch. How ever he came up with that number I don't know but the car always hooked good afterwards. Car was basically stock in the front end with a 'glass hood and the coilovers. Maybe something in that range 200 - 250 might be close for you.
Postby Eric David Bru » Sat Aug 04, 2007 11:55 am
I wonder if he was calculating the difference between the sprung and unsprung weight of the front of the car... ?
Postby pro70z28 » Sat Aug 04, 2007 12:07 pm
Or playin' Russian Roulette with the jacks. :roll: :roll: :roll: :roll:
dnewnova
spring rate
Postby dnewnova » Sat Aug 04, 2007 12:38 pm
Thanks Guys
I sat down last night and read my "DOORSLAMMERS" book again and re did the calculations from the diagram thereafter rechecking twice I came up with 225# so Thats what I will order but I am going with a slightly taller spring as well so as to crank some energy into them hopefully I appreciate your help.
Thanks
ps:Dave Morgan is a moderator over on www.Dragstuff.com with Dave Lemmond
dnewnova
Maritime
Postby dnewnova » Sat Aug 04, 2007 12:43 pm
Looking back you were right on with your range
so my other 10,000 questions on setting my car up are !!!!!!!!!!!!!!! :P :P :P :P :P
Postby Eric David Bru » Sat Aug 04, 2007 12:56 pm
One would hope that they had some jackstands under there as well... :oops:
