That's what I used, dumped some in each cylinder and left it sit for the weekend. I disconnected the drive shaft, put the tranny in high and turned the drive shaft with a pipe wrench and a long pipe. After a few flying leaps it broke loose.X2 on the 50/50 acetone/atf mix.
Acetone has a high absobtion rate that makes it penetrate like a terror. I use this mix all the time. The best Ive found.
Good luck Pappy.
Al
Users browsing this forum: Google Adsense [Bot] and 7 guests
