WHICH STACK INJECTION ???
Postby SLICK VIC » Thu Jan 11, 2007 12:25 am
I am going to put a stack injection set up on my 505ci BBC
i was wondering which brand and what size to go with, any body
knowledged in this field for advise.
505ci 800 plus hp @ 6800 rpm
13.5 comp
dart pro 1 335 cnc heads
.817 intake,.774 exh,...280/288,..112lc
powerglide 5800 stahl,..1.76 first
4.30/4.56 gears,.....34.5x16x15
thanks in advance,.....Vic
Postby Novel-T » Thu Jan 11, 2007 2:48 pm
I think you are limited as to who still makes them.Hilborn,Crawford, and Ron's Fuel Injection owns the rights for the old Crower set like I have.
Postby SLICK VIC » Thu Jan 11, 2007 3:32 pm
Thanks Novel.
what determines what size the throats should be ?????
or how you would determin what size ?????
thanks
Postby Novel-T » Thu Jan 11, 2007 8:13 pm
Hilborn suggest pump size per cubic inch,but I didn't see anything about tube size.My Crower has 2 7/8"tubes going on 439cubes with a Hilborn 150-1 pump.the system came off another BBC,that was 468 cu in.Hope this helps.
Postby SLICK VIC » Thu Jan 11, 2007 8:18 pm
thanks Novel-T,
............every bit helps.
Users browsing this forum: No registered users and 8 guests
