elec pumps
elec pumps
Postby gary b » Mon Mar 05, 2007 9:54 pm
on electric fuel pumps with bilt in ajustable bypass can you run the return back to the intake side like we did on the mech ones ?? or does it have to go back to the tank. thanks gary b
Postby gary b » Tue Mar 06, 2007 5:48 am
this must be a dumb ? anyone ever tried it? i wonder if if the fuel will loop and not pull from the tank? thanks gary
Postby greenracing » Tue Mar 06, 2007 7:35 am
I haven't had that many things with electric pumps on them... I would think it should work. If you figure that the pump doesn't know whether it's being driven by an electric motor or the camshaft, what works for one should work for the other.
Postby SLICK VIC » Tue Mar 06, 2007 9:45 am
Electric pump saver......
Postby Rapid Randy Baker » Tue Mar 06, 2007 11:45 am
Well, generally you want the electric pump to push. So it is mounted back at the tank anyway, it would be easy to just return to the tank. That is how I have always done mine. Not saying that is the correct or only way.
The other thing to consider is that an electric pump heats the fuel, and is cooled by the incoming fuel. So if you loop it, and run it a while you are sending hot fuel to the engine, and heating up the pump as well. JMO
Postby gary b » Tue Mar 06, 2007 8:06 pm
cooling the pump i never considered. put to big a radiator in i guess can't get another 10 line around it for the bypass. thanks randy and every one. back to the drawing board. gary b
