Setting up the clutch
Postby draglist » Mon Feb 04, 2008 1:24 am
Got this via email...
hey guys looking for a little help on setting up clutching . I'm pulling hard to 115 but i just cant get over that for some reason. i have checked the basics and i know I'm not getting a full shift as the rpm does not climb. thanks, Joe
Postby Rapid Randy Baker » Mon Feb 04, 2008 10:59 am
Joe,
I am not real sure I understand exactly what you are asking. However MPH is a product of engine RPM-Gear Ratio-Tire size. It might be you are running out of engine, not clutch. Check your valve springs and fuel flow.
Good Luck,
Users browsing this forum: Google Adsense [Bot] and 12 guests
