Injected sidekick muddragger
injected sidekick
Postby injected sidekick » Fri Apr 04, 2008 11:10 pm
I thought I would throw in something a little different, we drag race also but we do it in 160-200' in the dirt/mud. Typical capable times of 2.3 to 2.7 seconds in 160-180' the conditions obviously vary from track to track :shock:
1989 Suzuki sidekick
Chassis Specs :
OEM frame rails w/modified and fabricated suspension and cage
Fabricated rear 4-link w/pan hard bar and Fabricated front 3-link suspension w/ pan hard bar
9" ford rear, Superior axles, strange spool, 4.56 pro gears, QA-1 single adj rear shocks and Disc brakes
Dana 44 front, Superior axles, open diff , 4.56 gears, QA-1 single adj shocks and disc brakes.
Electric/hydraulic pump w/6" hydr ram front steering system.
Edge converter, modified C-6 trans and NP-205 transfer (1.96)
40" cut bogger sor 32" paddle tire (rear) 38" cut boggers (front)
15x18 rear wide- 5 alum rims and 15x12 front wide-5 alum rims
Engine Specs :
514 CI Alcohol Injected BB Ford
4.150 Forged stoker crank
6.800 Alum billet rods
14.8 to 1 Diamond pistons
MSD crank trigger / pro-coil HY-Fire VI ignition
Herbert Solid roller custom grind - 780” lift 290 intake 280 ext 110 center
Crane gold 1.73 roller rockers , roller lifters, SVO girdle
IDT Eliminator A-460 Alum heads - Titanium 2.400 intake /1.88 ext valves. ( flow 450 cfm Int /320 cfm Ext @ 7500 RPM)
Enderle Bird Top Hat Injection, 80A-1 pump , square barrel valve
950 Horsepower (estimated) all motor
Here are some Pic's please enjoy
Last edited by injected sidekick on Fri Apr 04, 2008 11:57 pm, edited 1 time in total.
Postby draglist » Fri Apr 04, 2008 11:23 pm
Wow... that is one bad*ss hot rod! bp
F/C Girl
Postby F/C Girl » Fri Apr 04, 2008 11:37 pm
this is Cool!!!
Mini Monster truck!!
Did I miss what kind of times you guys do?
How Fun!!!
Nancy Matter
Nancy Matter Racing, Inc.
http://www.nancymatterracing.com
injected sidekick
Postby injected sidekick » Sat Apr 05, 2008 12:04 am
Thanks guy's :lol:
F/C Girl - I forgot the times, but I edited them in. Typicaly depending on track we run around 2.3 to 2.7 seconds in 160-180' tracks on "all motor"
Were are contiplating a 250-300 direct port nitrous kit this year. But we haven't made the commitment yet. Were legal to do so in our class. We could possibly expect to see 1,9's to 2.3's . But getting the horsepower down/hooking becomes critical with these changes :shock: :lol:
Jeff
Postby Billy Mac » Mon Apr 07, 2008 5:33 pm
COOOOOLLL.....I Yike da motor!!!!...(note avatar<< :wink: ....)
Postby Eric David Bru » Mon Apr 07, 2008 8:47 pm
Jeff,
Nice to see the buildup picts... I had never seen them before.
Big Erik
Postby Big Erik » Tue Apr 08, 2008 3:14 pm
wow thats pretty cool!! ERIK
I'm everything they say i am......I'm so bad......Baby i don't care!!!
