TH400 dual feeding
chevyv8_power
TH400 dual feeding
Postby chevyv8_power » Fri Apr 25, 2008 10:42 pm
I have been reading a lot on the forums about dual feeding the direct clutch but am still not sure how to do it since there seems to be different ways of doing it. Plus I don't have a tranny to take apart and look at right now or a fluid diagram to look at. I have a TH400 with a B&M transpak(shift kit) and want to dual feed the direct clutch.
Is it as simple as plugging the feed to the accumulator in the valve body?
I did not remove any seals in the clutch or a pump sealing ring. The kit modified the accumulator if I remember right, I think replaced it with a different one and blocked a hole on the outside of the valve body. Also a hole was drilled larger on the separator plate but I think that was for 1-2 shift. I am trying to firm up the 2-3 shift.
Users browsing this forum: No registered users and 51 guests
