RUNS OUT OF STEAM
RUNS OUT OF STEAM
Postby SLICK VIC » Wed May 10, 2006 10:02 pm
80 MALIBU 2600LBS POWERGLIDE 1.76
BBC 505 4.25 X 4.280.(100 OVER), 14.5 COMP, JE PISTONS
DART 320 HEADS, GOOD INTAKE,
HOLLEY (#8896)1050 DOMINATOR,
CAM.. 714/278 INTAKE..680/282 EXH.
4.30 GEARS, 33 TALL X 15 SLICKS.
CAR DOESNT WANT TO RUN ANY FASTER AFTER 900 FT
LOSES ITS GIDY UP 6800 RPM 9.02 ET SHOULD RUN 8.80
MOTOR GOOD TO 7400 RPM....
TRIED FOUR DIFFERENT CARBS, TWO DIFFERENT CAMS,
ONE OTHER SET OF HEADS, PUT BIGGER FUEL PUMPS ON,
REGULATORS ETC.....REGARDLESS PLUGS
ALWAYS SHOW LEAN (WHITE) AS IN NO FUEL AND WONT
PULL THE FULL QAURTERMILE.
COULD SOME HOW OR ANOTHER THE CARB BE LOSING
ITS SIGNAL DURING WOT PREVENTING ANY MORE FUEL
FROM ENTERING MOTOR ??? ANY SUGESTIONS OR ANSWERS
THANKS VIC
Bgreene
Postby Bgreene » Wed May 10, 2006 10:42 pm
Hey Vic,What kind of fuel pump,regulator and size fuel line ? Whats the pressure on the regulator? what kind of fuel? just because you have pressure doesn't mean you have volume.Is it nosing over at the shift or just at 900 foot. I know it's a lot of questions but hopefully we can get you figured out.
Postby Bob Kraemer » Wed May 10, 2006 11:07 pm
What size of fuel line from tank to pump?
How new or old are the valve springs?
Does the carb have jet extensions?
What kind of fuel pressure?
How much timing?
How much front end lift on the big end? to much will affect level in float bowls.
What type of ignition system? Bad box means car won't get out of it's own way.
Disconnect lines from carb and see how long it takes to fill a 1 gallon container. A 10 GPM pump should fill a 1 gallon container in six seconds.
Postby SLICK VIC » Thu May 11, 2006 1:11 am
-12 TANK TO PUMP
-10 PUMP TO REGULATOR
-8 TO CARB
BG REGULATOR BIG ONE
FUEL PUMP MEGA 500..ALSO HAVE RAN THE BG 400
FRESH VALVE SPRINGS
7 PSI @ IDLE AND AT OPEN THROTTLE NO CHANGE
36 DEGREES TIMING
NOT SURE ON JET EXTENSIONS
7AL 2 MSD ALL MSD IGN
NO MORE THAN 8 SECONDS TO FILL 1 GALLON
110 OCTANE
IT DOESNT NOSE OVER AT ALL, JUST STOPS PULLING LIKE
IT RAN OUT OF GEAR AT THE BIG END. OR FUEL ????
PLUGS ARE WHITE
Maritime Drag Racing
Postby Maritime Drag Racing » Thu May 11, 2006 8:35 am
Couple of possible gremlins here:
Before you go crazy trying to track this problem try swapping out your fuel pressure gauge for another one just to eliminate it from the mix. Friend of mine chased what he thought was a fuel delivery problem for months before he finally tracked the problem to a fuel pressure gauge that was reading too high.
Saw the same symptoms one time from a too small fuel cell vent that was only noticed the first time the car saw a chassis dyno. Trunk lid was off and one guy standing behind the car saw the sides of the fuel cell suck in just as the dyno run was almost done. After a larger vent was installed the "laying down" at 1000 feet stopped.
Postby Novel-T » Thu May 11, 2006 9:43 am
I like Maritime Don's vent idea.Also what about electrical power.do you run an alternator?Msd say's their bow want 1volt per thousand rpm. from what you said,6.8v will be needed to run the box.That leaves 5.2v to run the fuel pump and everything else.
Postby flyinhillbilly » Thu May 11, 2006 7:28 pm
you might want to switch to .150 needle and seat, the fuel column will actually dwindle away to where you are just running off of what the will flow through the needle after a certian amount of time at wot, the larger needle and seat help slow down this eventuality, and as a side benifit you can run less fuel pressure which results in less areation of the fuel which means more udn udn, because areated fuel causes a lean condition. just this dumb hillbilly's suggestion.
Re: RUNS OUT OF STEAM
Postby flyinhillbilly » Thu May 11, 2006 7:31 pm
[quote="SLICK VIC"]
PULL THE FULL QAURTERMILE. or you could just start racinc 1/8 mile
Postby Billy Mac » Thu May 11, 2006 7:35 pm
try the 1/8th...you "might" like it :roll:
Postby SLICK VIC » Thu May 11, 2006 8:13 pm
IVE RUN 1/8TH MILE BEFORE, BUT THE 1/4 MILE
IS TO SHORT AS IT IS.... :lol:
THANKS FOR ALL THE INPUT GUYS,
HERES SOME MORE INFO..........
CAR HAS FRESH MOTOR FROM LAST YEAR
USE TO RUN 9.02 TO 9.06@ 146-8 ANY WEEKEND THEN
IT STARTED TO ONLY RUN 9.20`S THEN 9.30`
MADE ALL THE CHANGES AND IS NOW BACK TO
ONLY RUNNING BEST OF 9.30`S AT SAME TRACK
AND CONDITIONS. WORST WEEKEND ET IS 9.40
SHIFTS JUST FINE THREW 7200 RPM,
OCCASIONAL SMALL POPPING THREW EXHAUST
ON TOPEND...LEAN...........CRAZY A....... :x
THIS IS ONE FOR THE HISTORY BOOKS.
THANKS AGAIN.
ANY OTHER HELP VERY APPRECIATED
Users browsing this forum: No registered users and 8 guests
