bolt pattern
bolt pattern
Postby gary b » Sun Jun 11, 2006 7:59 am
looks like i did it again.. help!! seems i've bought a rear end with a bastard bolt pattern one set has 5/8 studs and measures 4.250 or 110 mm the other is 1/2 stud size (no studs) 4.5 inch bolt pattern.. got any idea's what kind of wheel and brake hat's they could of used. i hate to pitch the Axel's there strange gun drilled 35 spline..i should of knowed the price was to good (swap meet) thanks Gary b
Postby pro70z28 » Sun Jun 11, 2006 9:31 am
Can you redrill 'em so they match each other?
Postby gary b » Sun Jun 11, 2006 11:21 am
opps they have two bolt patterns on each axel.. 110 milimeter and 4.5 small ford.. but the studds are in the 110 holes.. could redrill the 4.5 holes to 5/8. but finding good used wheels are going to be tuff.. seems most of the wheels i'm finding are either 4.750 or 5 inch.. just never heard of the 5 bolt 110 mm bolt pattern. thanks gary b
Postby Novel-T » Tue Jun 13, 2006 9:38 am
Gary,I think early Valiant and Duster bolt pattern was 4.5inch
wheelzman
Postby wheelzman » Tue Jun 13, 2006 11:17 am
:?: I have been selling custom wheels for almost 20 years and never heard of a 5 x 110mm. So I looked in my application book and the only thing close was a Mercedes at 5 x 112 mm. Are you sure you measured correctly? On 5 lug you measure from the outside of the hole to the center of the second hole. And T the early Mopars were 5 x on 4" and this bolt pattern was exclusive to them for about a four year period. Nothing else has that pattern. :?
Postby Novel-T » Tue Jun 13, 2006 8:19 pm
Wheelz.Brain fade here,it's been a long time since I had my 65 Cuda.The wheel selection was about 2 types.
Postby Gator » Tue Jun 13, 2006 8:23 pm
I like the cardboard or plastic jiggers (cheaters) with multiple patterns..keep trying until you hit the correct pattern
(or I'd call Wheelzman now)
Postby flyinhillbilly » Tue Jun 13, 2006 10:42 pm
i think some front wheel drive stuff has 5 on 110mm, lot of good that'll do you though :?
bolt pattern
Postby gary b » Sun Jun 18, 2006 6:04 am
wheelzman when your right your dead on.... measured wrong ... from outside to center 4.5 and 4.750.. thank you very much no telling how much you saved me... started to by a custom set of wheels.. new car is coming along nice.. down to buying wheels tires and electronics.. four link went together easy hope i bought the right coil over shocks and springs thanks again everyone gary b
Postby Lippy » Sun Jun 18, 2006 12:55 pm
Gary, glad to hear it's coming together! 8)
Users browsing this forum: No registered users and 157 guests
