Milan Dragway -July 6th "Special Edition" RWYB -$5000 to win
Milan Dragway
Postby Milan Dragway » Wed Jun 20, 2012 1:40 pm
Dear Run What You Brung Racers,
Don’t miss out on the DTS Friday Night Heads Up Series, July 6th , with $5000 to win!
Come out the day before and take some hits at the track, we will have a Pro testing session available.
For those that are traveling to or from another event, we invite you to use our facilities and park
throughout the week.
Below you can find the payouts and rules for the “Special Edition Run What You Brung” class.
July 6th, 2012 Run What Ya Brung - RWYB
Napa Auto Parts 16 Car Field
1/8 Mile, Heads Up, .400 Pro Tree, 8 Car Field, Pro Ladder
Open to any type of "Door" Car - Pro Modified, Pro Stock, Pro Street, Pro Outlaw, Top Sportsman
No minimum weight, tire size, engine size, unlimited power adders
Lower Engine Containment Device Required:
Oil Retention Device:
Device may be custom-built ballistic blanket-style or metal-style (I.e., bucket) device.
Metal pan may be no longer than the engine from the front of crank shaft to the rear of the flywheel. Pan must be inside the
frame rails and fabricated to retain oil\liquid. Pan must attach to the frame via conventional fasteners or straps.
Pan must be a minimum of 3inches above ground.
Diapers: They do not have to be SFI rated.
MUST MEET ALL NHRA RULES INCLUDING LICENSE AND CERTIFICATION
Payouts
$5000 winner
$1000 runner up
$250 semis
$100 quarters
Entry fee $100
