CHECK OUT BILLET CONNECTIONS NEW PRODUCTS!!
MikeC6641
Postby MikeC6641 » Sat Nov 02, 2013 5:29 pm
BILLET CONNECTIONS NEW PRODUCTS!! @ http://www.billetconnection.com
Including THE NEW!! Push Rod and Wrist Pin Checking Tool designed to check the run out and straightness of both Push Rods and Wrist Pins of all sizes.
Go to http://www.billetconnection.com to Check out other Specialty Engine Tools, like the best Valve Spring Compressor Tool on the market.
Also check out Billet Connection's Oil or Fluid See Through Filter Assemblies which give the user the ability to keep track of their engine or equipment by being able to visually check the filter element in seconds without draining or leaking any fluid, unbolting or loosening any fasteners or fittings and without the loss of any fluid out of the system, for more information on these filters & to order go to http://www.clearviewfiltration.com or http://www.billetconnection.com
Billet Connection
mike@billetconnection.com
509-467-7584
THE NEW!! Push Rod and Wrist Pin Checking Tool ( http://www.billetconnection.com )
Valve Spring Compressor Tool ( http://www.billetconnection.com )
Oil or Fluid See Through Filter Assembly ( http://www.clearviewfiltration.com )
4in Screwon Filter(small).jpg (84.11 KiB) Viewed 4349 times
Last bumped by MikeC6641 on Sat Nov 02, 2013 5:29 pm.
