does anyone know what hardblok is made of?
Postby flyinhillbilly » Fri Aug 04, 2006 10:50 pm
i've heard rumors that it's just repackaged grout, does anyone here know for sure? i'd hate to pay 75 bucks for 11 dollars worth of grout if that's the case.
Postby stimpy » Sat Aug 05, 2006 2:25 am
I heard it was a mixture of hydraulic cement and grout with some sort of resin as a binder .all I know the stuff is better than plaster of paris or fibreglass resin( we used the resin and it would soften from the heat of the engine and flow in the passages and the plaster would disintegrate from the hot water )
Postby Leon » Sat Aug 05, 2006 10:28 am
Part of Randys cake mix?
Postby stimpy » Sun Aug 06, 2006 2:02 am
I don't think Randy would part with anything that has to do with cake . :lol:
More like my Exwifes pancake mix otherwise known as manhole cover mix . :twisted:
Postby Gator » Mon Aug 07, 2006 7:56 am
A good friend of mine owns HardBlok..It's a pretty high tech, lab/field tested product.
We used a ton in our day.
good stuff..worth the $$'s.
Deano
Postby Deano » Fri Sep 08, 2006 12:26 am
I've used it for six years never a problem
We all know that life is a jungle but it don't matter if you're a tiger.
Maritime Drag Racing
Postby Maritime Drag Racing » Fri Sep 08, 2006 8:27 am
Take a tip from a retired Boiler Operator - use refractory cement. It'll stand a lot more heat than an automobile engine will produce and cure high pressure water leaks too. Over the years I've dragged home a good many bags of it for local racers. Just don't mix it too thin and make sure you vibrate the block with a palm sander or air chisel when you're pouring it.
Postby Gator » Fri Sep 08, 2006 4:53 pm
pre-Hard Blok...we did that.
Hard Blok is Bitchin' !
Excellent product.
worth the little that it costs
Users browsing this forum: No registered users and 51 guests
