Gapless rings.
RobbieG.
Gapless rings.
Postby RobbieG. » Sat Mar 11, 2006 10:34 am
Are gapless rings (perfect circle) worth the money?
I'm getting ready to put my race motor back togeather and I don't know weather to run gapless, moly, or just cast rings. I don't make a ton of HP so is it worth the expence.
Help me deside guy and gals.
RobbieG.
ThunderHorse Racing
Robbieracer
ThunderHorse Racing
Postby Gator » Sat Mar 11, 2006 5:29 pm
They seal good Robbie
Postby Lippy » Tue Mar 14, 2006 3:45 pm
I'm with Gator, go gapless if ya can.
RobbieG.
Postby RobbieG. » Tue Mar 14, 2006 8:24 pm
Ok, sounds like a dumb question. I HEARD that you have to hone the bores differantly for gapless. Is that true.
Robbieracer
ThunderHorse Racing
Postby Rapid Randy Baker » Tue Mar 14, 2006 9:30 pm
Robbie, I think there is probably something to be gained from them at certain power levels. At what level, I am not sure. I think the different hone is related to cyl clearance with this style ring. I know I have heard some stories of ring flutter in the upper ring due to the sizing of the 2nd ring.
If you go to InsideTopAlcohol.com, search the tech threads and you will find some info on them.
AJ also may have some thoughts if he checks in. We used to use them, and now we don't.
Postby greenracing » Wed Mar 15, 2006 8:57 am
We've used them over the years in the KB and now I'm using them in the Donovan. At the time it just seemed like a good idea, and they seem to work well - we always had pretty decent leak downs with them. I believe it reduces the amount of fuel that ends up in the oil pan, seems like we can get a bit more runs on an oil change.
Postby Gator » Thu Mar 16, 2006 5:40 pm
a planned leak was (probably still is )a trick......
nhra used to check prostock oil.......
But , that's a different deal.
Deano
Postby Deano » Fri Sep 08, 2006 12:33 am
I've used them in my last three engines and like them.
Heck I save on oil changes as it's not easy to dilute the oil with alcohol
We all know that life is a jungle but it don't matter if you're a tiger.
Postby Rapid Randy Baker » Fri Sep 08, 2006 9:03 am
Hi Dean,
Welcome to the board 8)
Deano
Postby Deano » Thu Sep 14, 2006 6:46 pm
Thanks Randy
Love your avatar
Users browsing this forum: No registered users and 58 guests
