Headers for my 66 Fairlane
Postby draglist » Wed Mar 15, 2006 10:12 am
Hi Bill, my name is Mike Loyning and I am writing in regaurds to finding a set of headers for my 1966 Fairlane. I was referred to Jack Davis headers from a guy named Stephen Johnson. I understand he runs Jack Davis headers on his 67 427FE four speed Fairlane. The Hooker Super Comps just don't have big enough primary tubes for my engine. My engine is a 390 FE bored and stroked to 445, 11.25:1 compression and solid roller camshaft. You should know as well I will be running a TKO600 five speed transmission. I contacted Stephen after reading about his car in the March 2005 issue of Muscle Mustangs and Fast Fords. It shows his car doing a wheelstand with a perfect view of the headers and I'd like to run those same ones on my car if I could. Any info on this subject will be greatly appreciated. Thanks for your time, Bill.
Sincerely, Mike Loyning loyning20@yahoo.com
Postby Billy Mac » Fri Mar 17, 2006 12:13 am
I'd prolly have a custom set built.....that way, you get the primary size you desire, PLUS they "should" be made to fit......We start off with a "kit" and custom fab from there.....then we send 'em off to be coated......Good Luck! 8)
Postby Gator » Fri Mar 17, 2006 7:01 am
call or e-mail Animal Jim..
He may have some.
animal jim
Headers for FE
Postby animal jim » Sat Apr 01, 2006 8:42 pm
8) When I ran 427s-even Tunnel Ports in the Big Animal I used Hookers # 6205 with 1 7/8 tubes and 3 1/2 collectors. The 4000 lb. Big Animal 57 Merc with the Tunnel Port, (I had two identical TP engines one with a .651 General kinetics flat tappet and one with a special grind Crower Roller .622 lift.) Both engines ran the same. Mid 11's 120 to 126 mph. Stock rockers, Accell duel point, Super Coil, 2 660 Holley Center Squirters with 50 cc pumps and spaced 4". Stock Ford TP pistons and LeMans Rods. Simple engine. 600 hp. :) :idea: :wink:
4 speed Top loader-5:43 gears. A fun ride. The Hookers did the job fine for bracket racing. :wink:
In 75 I had a 71 Comet-with same engines-I did try Hooker 6395s with 2 1/8 primaries 30-38 length and 3 1/2 no flange headers. This car was for local heads up pro Stock class. Comet was 2700 lbs. Awesome power-I crashed it before I could really wring it out. Detroit Locker malfunctioned and locked one axle only! In 4th. Gear!! - :shock: :shock: Goodbye!!! :cry:
You can see all this on www.animaljimracing.com Clink on my Career Gallery. 8)
It has been quite a ride!
Postby draglist » Sat Apr 01, 2006 9:00 pm
Thanks, Animal... the FORD ANSWER MAN! bp
Re: Headers for FE
Postby flyinhillbilly » Mon Apr 03, 2006 10:19 pm
8)
<<<<was born in 1975 :shock:
animal jim
Super Stock in the 70s/80s
Postby animal jim » Tue Apr 04, 2006 10:50 am
The 6395 Hookers where also used by SS ace /record holder Jeff Velde in his 69 Mustang, Sam Johnson in his 427 MR 67 Fairlaine and Bruce Miller's record holding D/A 428 69 Mustang. I know they did lot of experimenting with tube extentions and collectors. 8)
Jim & Ray Paquet is someone else to ask about headers. I have Jim's number-I think it is still good. 517-663-0578. He owns Jim's Performance Transmissions in Eaton Rapids, MI. Ray & Jim were famous for T-Bolts. Both are Ford FE icons in NHRA sportsman classes. :wink:
I was born in 41!!!??? F---k-I'm Old!! :shock: :shock: :shock: :shock: 8)
I will tell this however-lot of what worked 30 years ago still does! :wink:
Don't overlook good old fashion baseline common sense to present hype/buzz word ideas and popular marketing-but do take advantage modern techknowlegy if to your advantage.
Postby jim sanders » Tue Apr 04, 2006 12:06 pm
i GRADUMENTATED IN 1975 and also have a 1966 390 motor under the work bench no headers tho... do have a pair of bbc weedburners in the rafters
My427stang
Postby My427stang » Mon Apr 28, 2008 6:38 am
Animal Jim, another Ford guy, new to the site here.
Digging through your web page now, great website and career
70 Mustang FB, 489 inch FE, TKO-600
71 F-100 4x4 SB hot rod truck, 390
07 HD Street Glide
08 F250 4x4 CC 6.4 diesel (love them diesel prices)
injected sidekick
Postby injected sidekick » Wed Apr 30, 2008 5:05 am
Animal Jim - Stop on over at www. 460ford.com it is an all ford site. Be a pleasure/honor to have you over as a member. Thanks
Users browsing this forum: No registered users and 24 guests
